BurbMan
May 17, 2005Explorer III
Not quite....mathematically, you are right, moment = force x distance. BUT, increasing the distance only lessens the force required to produce the same moment. If we assume that the crosswind is blowing at 20mph, changing the length of the lever is not going to make the wind blow slower. Further, we can assume that the wind gust exerts pressure at all points along the side of the trailer, not just at the coupler, so theoretically, there are an infinite numbers of points where force is applied, each with corresponding moments from the TT axle.
Of course, the same wind is applying its force to an infinite number of points along the same side of the TV also, so does that produce a series of counter moments?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
