Stressor
Jun 07, 2005Explorer
ttsr4us wrote:
I have read this with great interest. I am a Hensley owner and it taimed my sway problem which my Reese Dual Cam was unable to do. I am reaching some understandind about how this hitch works but am not quite there yet. One problem I have is that I am able to move the hitch from the TT end when I insert a bar into the hitch to unlock the drop down bar which prevents the hitch from moving when disconnected from the trailer. I can rotate it around quite freely buy pushing into the TV direction and applying a rotating force at the same time. So is this a force direction issue, ie tension rather than compression which would also explain why the brakes on the trailer have to be set correctly? Sorry to stir the pot but I have not seen this aspect discussed. (I may have missed it)
If I read this correctly, you are actually moving the tow vehicle end when you are inserting a bar to move the lock out of the way. You have become the stinger and tow vehicle. It is not a force direction issue, it is strictly a linkage issue. The linkage is narrower at the TV end, and movement can occur due to simple leverage.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
