AO_hitech
Aug 31, 2005Explorer
Stressor wrote:
The cable is not attached at the same point as the weight distribution bars, those are what is flapping in the breeze out to the sides in the picture.
Although it is not attached to the exact same point as in a std WD hitch (since a std WD hitch doesn't have the exact same point), it is still a far comparison. From appearances you are applying force to a point an in a direction that I would not expect the hitch to move REGARDLESS of it's sway control abilities.
Stressor wrote:
Go here if you will, and read what it says.
While the HA appears to be a superior product, I wouldn't take the manufactures word for it. I've seen WAY TO MANY marketing departments that outright lie when it comes to what their products are capable of and how they work. I'm FAR more likely to believe the patent application. Not that those are exact either.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
