tluxon
Sep 02, 2005Explorer
I decided to put a little work into seeing what arc the coupler travels through as the trailer rotates in a "swing". It took a little time to construct the points so I stopped at 8 degrees in each direction.
What I learned from this is that in the first 8 degrees of swing, the coupler gets 2.15 inches closer to the tow vehicle. This simulates a pretty short pendulum which makes the lifting wedge angle fairly steep. It appears to me that a strong tension between the TV and TT would work quite effectively at keeping the angle within a few degrees of center. I'm curious to hear what Ron has to say about it.
Tim
Tim
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
