TnAnFLA
Sep 07, 2005Explorer
drfife wrote:
The struts can be in tension or compression while towing depending on the direction of the applied forces.
Actually, you'd best hope they stay in compression while towing. When you snug them up, tightening the nut places them in compression. Ideally not a lot, but definitely in compression. If the forces on the TT are enough to take them out of compression, it would have the same effect as loosening up the lock nut to the point that the struts are no longer snug, and then the coupler is free to rotate on the ball on the upper unit of the Hensley. And if it got too loose, all bets are off on effective sway control, since you've added yet another pivot point.
Andy
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
