Second_Chance's avatar
Second_Chance
Explorer II
May 22, 2016
High capacity 20" tires for truck
I posted this on the Silverado/Sierra forum and got one response... "good luck." Since folks on this forum are more into towing than jacking trucks up to make them look macho, I'll see if anyone here knows of anything:
My wife and I are full-time RVers. Our truck is a 2013 Sierra 2500HD SLT CC D/A with the 20" wheel option. While the 20" alloy wheels look very nice, I'm having trouble finding a higher capacity tire than the stock LT265/60R20 load range Es that came on the truck. I'm looking for input on either: 1) load range F tires in the LT265/60R20 size, or 2) suggestions for replacement wheels in a size where load range F tires would be available without changing the outside diameter of the tire/wheel combo (currently 32.5"). I'm happy with the current gear ratio and the performance of the D/A when pulling our house-on-wheels. I could tolerate a slightly smaller diameter, but not anything larger (wouldn't mind a few more RPMs at cruise where the tranny would shift into 6th a little sooner).
The pin weight on our fiver as currently loaded is right at 3,000# which puts us just barely under the rear axle rating (GAWRR) for the truck when pulled across the scales (verified both on CAT scales and a wheel-by-wheel weight system proprietary to one of our RV clubs). The total capacity of the tires is a few hundred pounds above the axle rating, but I'd still like to increase that safety margin. I understand that no aftermarket modification (tires, air bags, etc.) can/will increase the ratings of the truck... it is what it is. I'm just looking to increase the safety margin on the most likely thing to fail.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.225 PostsLatest Activity: Jul 18, 2025
