Camper_Jeff___KNavigatorFeb 14, 2025Leaking Expansion/Freeze Plugs The engine is in the truck and runs great. MPG with TC was 9.4, nothing to especially write home about. The problem I'm having is coolant leaking out of 2, possibly 3 plugs. 1 left, 1 right, and poss...Show More
StirCrazyModeratorFeb 15, 2025how bad are they leaking? I have never had a freeze plug leak so I am wondering what they use to get them to seal.
Grit_dogTrailblazer to StirCrazyMar 07, 2025Freeze plugs gotta come out. And reinstall with sealant. There is not proper in-frame fix for inaccessible ones.
About Tow VehiclesFrom fifth wheels to teardrop trailers and everything in between.257 PostsLatest Activity: Sep 17, 2026
Related ContentNautilus P1 has leaking connections7 pin plug amperage rating?Lippert faucet leaks, replaced with MoenOverhead Cab Leak on 2005 Winnie MinnieWater Heater Leak on start up.
