I'm waiting till the end of the break in period. If there is a problem, the builder says to contact him and he has a fix for the leak. The leak has slowed but not completely stopped. We'll see how things turn out.
I guess you kinda need to play along with the seller for warranty, however sounds like you’re hoping for a miracle and avoiding the reality of it. Freeze plug sealant doesn’t cure more  or expand or migrate over time.
the only way a leak path would seal is via radiator sealant, a high concentration of minerals in pure water “clogging” the leak or divine intervention.
But you know this, unfortunately. And the warranty was useless in this situation because it doesn’t cover labor and it’s easier to fix than taking the engine somewhere to put in a new freeze plug or 2.
Bummer, man.
