FishOnOne
Dec 08, 2024Nomad
2025 Cummins
Looks like Cummins learned that the 2019 release had significant design problems. Let's see if they finally fix them for 2025. (6) Master Tech Breaks Down The Cummins Updates For 2025! - YouTube ...
So here's a quick look at the 2025 6.7 Cummins
Aluminum head
Back to cast iron block instead of CGI
New Water pump
CP4.2 pump
Oil filter cartridge cannister
2025 RAM HD Cummins Photos Leaked! Master Tech Breaks Down The Good And Bad Changes - YouTube
Looks like cummins can't standardize their engines for the long run like they used to.
its probably because of emission changes. and trying to keep up to ford and chev in the power wars. little harder with two less cylinders on both fronts. I would be interested to find out why they are going back to cast iron blocks.
