Agreed on power. My Dad had a late 1970's Dodge van with the upgraded 360 and I think is was 225hp. I had a 1992 f250 7.3l diesel that had 180hp and was a towing machine in it's day..
Now I don't think you can find a 6cyclinder with less than 300hp and the turbo 4 bangers are well north of 300hp. For 3/4 or 1 ton trucks, they mostly start around 350hp and going above 400hp is common without even getting into the diesels.
My first NEW truck was an 81 C2500 with a 120'ishHP 292 I6. Compared to my current 1500 with a 285/305, I've pulled a 4% grade at 50-53 mph with an 8500 lbs trailer behind me! That 292 would be in 2nd gear of a muncie 4sp barely doing 20-25mph. The gearing in it made it pull steeper grades at heavier gvw than the BB V8's with the 3 sp TH400 behind them. I stalled them puppies out more times than I care to admit!
Amazing what a little more HP and torque, add in 2-7 more gears, and you have the ability to do better! I can imagine my 96 6.5td with an NV5600 vs the 4500, having to drop from 50 at 1700 rpm on a hill, to 50 at 3200 redline, dropping to 35 at 2600 for a smoother quieter drive up a 4% freeway grade,. the 6 sp would have put me at 40-45 at 2600 rpm due to being a 1.3 vs a 1.6 gear below direct!
Marty
