Mr_Usa
Jul 29, 2009Explorer
Show your mods!!
This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
Starcraft21SSO wrote:popeye59 wrote:
I have one of those gas gauges on my gas cooker tank at home. Found it to be less than accurate and wasn't going to waste more money buying on for the RV. Sure wish they made one that was accurate.
Just for reference, such an animal can't exist. Unlike compressed gasses (scuba, welding) where the pressure falls constantly during use, propane in the tank is a liquid that vaporizes at just below 110psi (@70deg). When you open the valve, the gas escapes, the pressure drops, more liquid propane evaporates, and so on. This continues until the tank is empty. It also means that the non-liquid space (gaseous propane) in the tank stays at approximately 110psi until ALL the liquid is used up, which is just minutes away from flame out.
