Mr_Usa
Jul 29, 2009Explorer
Show your mods!!
This is a removeable DVD stand I made out of conduit and wood for the back bunk in our Jayco 23B. swivels and tilted slightly. I also made one that will slide in the post where our regular TV sits for...
RustyFairmount wrote:
2L Water Accumulator Tank
Made from 4" PVC. Capped each end. Drilled and tapped schrader valve and 1/2" water line. Installed with cut-off valve on hot-water bypass (no red-pop will enter it). Total cost ~ $20 for the tank. Quiets pump operation. Runs longer, but less often.
