StirCrazy
May 07, 2026Moderator
basic answer is try it and find out. it is a pretty light rv. sway controle is a crutch for not loading the rv properly, you want 10% minimum of the total weight on the front ball. if it is less it leads to sway. weight distrubution is a totaly different purpose. that is to keep the proper ampunt of weight on the front end of the truck, and also to make it track over bumps in the road better. you don't get the dolphin swimming effect, instead the truck and trailer moove up and down togeather.
for what ti is worth I have never had sway control on a rv in 42 years. just weight distrubution when it is warented.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 24, 2026
