There are over a dozen DIFFERENT ‘half tons’ and some are right up there or near up there with 3/4 tons and most are down in the same as full sized cars & midsized pickups
Ford’s half ton Unicorn have a 7 lug wheel and GM’s half ton Unicorn have an 8 lug wheel.
At one time these ‘HD’ half ton’s had same or nearly the same RGAWR’s & GVWR’S as 3/4 ton pickups
Just trying to help this OP with metrics for them to figure it out themselves. They did say they already had the TV and looking at a trailer…the why suggesting of scaling the TV axle by axle and then using the trailer brochure numbers to figure an approximate situation for the setup. Edit…as they didn’t say which TV they have…just have a TV with a +12K MTWR
Expected the OPs TV to come out nearly at RGAWR capacity, unless they have that fabled ‘HD’ half ton and even then, might have limiting issues with the RGAWR.
Then with the TV’s actual weights, they can then look at other brochure specifications and still think they will find that those trailers will be way smaller than their original wants.
Assuming the OP is going to stick to staying under or within the OEM’s specifications
Here is a good site to read of those fabled ‘HD’ half ton’s
All you need to know about this heavy half-ton unicorn https://www.motortrend.com/news/chevy-1500hd-2001-2006-crew-cab-half-ton/
There are articles of the Ford fabled half ton, but this one should do it….
