Camper_Jeff___K's avatar
Aug 28, 2024
VIDEO: F-250 Enlarging Cold Air Intake Using Existing Parts Cheap And Easy 2000 F250 5.4 Liter
The air intake hole on my F-250 is 2-1/2" diameter. That is smaller then the throttle flap in the valve body. I looked at the components and decided to fabricate a new larger inlet pipe using the same filter housing and mounting bracket. I took two 3" ABS pipe couplers, and cut the outside half of one a quarter inch deep using a hole saw. I then used a larger hole saw to cut the outer diameter half way in and a quarter inch deep. I then took ABS glue and glued the two couplers to each other with the half inch overlap. I then took a 4" angle grinder and ground the bracket opening to 3-1/2" and also removed the small existing pipe on the filter housing going through the grill for cold air intake then drilled it larger with the 3-1/2" hole saw. I then stuck the ABS pipe into the new large opening on the filter housing and placed it as far forward into the housing as I could without pushing through. I still need to get some 1/2" to 3/4" rivets with backing washers and short metal strips, then drill holes for solidly connecting the filter housing to the pipe. The Blue RTV silicone you see is holding very strong as is in the video but adding the rivets will make it more solidly connected. I will do three rivets, 120 degrees of rotation apart to make the connection stable. It took a couple hours to do the project. A little oil on the plastic and rubber gromets on the underside of the filter housing bracket, will let you with some effort, pull the housing apart from the bracket. Clean the bracket, create your larger opening as neatly as possible. I used a 4" angle grinder. Grind, sand, de burr, then spray the whole bracket with black paint, 2 coats on the parts with bare metal. Stay tuned for updates on all the projects being done to upgrade this truck...
  • Nice mod I guess, but not anything that’s going to help from a real world seat of the pants experience.
    • Camper_Jeff___K's avatar
      Camper_Jeff___K
      Navigator
      We'll see what happens. I've done enough to the engine at this point where if it does make any difference, how would you be able to distinguish it from the other modifications.
      I have the thinner Cometic MLX head gaskets which will reduce combustion chamber volume by perhaps 2CC and raise compression by a fractional point or 3. I ported out the exhaust to be closer to header size and matched the ports to the headers for better flow. Installing the Y-Pipe to eliminate the 180 degree turn and the two choke points in the exhaust system, a high volume oil pump, and the coolant flow adaptors on the back of the heads to improve and promote more even cooling characteristics. I do expect to see more horse power, how much remains to be seen. The goal is to be able to hold speed on the highways in a headwind or slight uphill grade, and not dropping down to first or second gear when going over the passes. An additional 25 or 30 HP might be just enough.
