valhalla360
Jan 11, 2023Navigator
Double check the cargo stats. I tried to pull up what appears to be the model (it's not listed) and it shows a 14000lb GVWR, so about 4600lb cargo capacity. Probably adequate but I would want to run it by a scale before purchase as add on items can eat up a fair amount.
Also, what is your hitch rated for? At 1400lb, I would expect a hitch weight of around 2000# give or take once loaded. It likely will be worse when running without the 2800lb car in the garage. Keep in mind the weight distribution of the car can make a big difference.
Probably doable but what's the full truck info. While payload is often a limiting factor, this might be an oddball where something else becomes the limit.
About Toy Hauler Group
49 PostsLatest Activity: Aug 23, 2026
