dedmiston wrote:
Sprink-Fitter wrote:
That would depend what you call a standard garage, but the spider and the Harley side-by-side like it all up and see how much room they take up
I doubt they would fit side by side. The Spyder is probably close to 5' wide. Fitting the Harley in the remaining ~3' doesn't seem viable to me, especially with the symmetrical layout of the anchor points in the floor (the center tie downs would be underneath the Spyder). So assuming they don't fit side by side, he would need a longer space to fit one behind the other. That definitely wouldn't work in a garage.
Yeah, there is no way they will fit side-by-side. The Spyder is probably closer to 6 feet wide than 5 feet depending on the model. The Spyder could possibly be angled a little and the front tire of the Harley up beside the Spyder a little, but not very much because those things are wide in back too.
Pretty much in line with each other, which is why I specified a very large garage, but you're right, I don't think a separate garage will work very well. The Spyder could be backed in to the trailer and you wouldn't need as much width further into the trailer. Then put the Harley in the center between the Harley and the back door.
