trailerbikecamp's avatar
May 18, 2015
'03 CTD question?
Have a problem with my '03 CTD 5.9.
This past week I was I in a town about 3 1/2hrs away from home. On the way home I had to pick up DW about 3hrs from home. While waiting the truck started to idle rougher than usual. EGT are slightly lower while idling, but about 150-200* higher than usual. The truck seems to be down on power slightly, I estimate about 10%. There is also a terrible odour, very similar but not identical to brakes. Manually felt brakes and they are cool. Also noticed an odd sound while idling. It seems to sound like air is passing somewhere. Sounds almost like a vacuum leak, but at a higher volume. Engine temps are normal, tranny temps are normal, no lights on dash.
Air temps were about 68*F, no load on the truck, just myself and DW. Have definitely worked this truck harder in hotter temps. The truck has about 115K miles.
Any ideas where to start with this?
  • It seems to sound like air is passing somewhere
    You also mentioned less power... check turbo/intercooler boots and intercooler for cracks/tears/leaks, worn out boots/tubes can cause loss of power as air maybe escaping from the turbo or intercooler on the way to the intake. Also check intake manifold area, could be a leaky gasket.
  • What is the engine boost pressure doing ??
    Does the engine have a exhaust brake ??
