dodge_guy
Nov 15, 2015Explorer II
With 35" tires does it still have the factory gears or did they replace them. You will want a minimum of 4.30`s with those tires, 4.56`s would be ideal.
As for longevity, no need to worry they go a long time upwards of 400k miles with no issues.
The spark plug problem was fixed in 02.
Gas mileage should be decent for what it is. I can get 14 (with 4.30`s) on the hwy. towing my 9200lb 11 1/2 foot tall trailer I get 8mpg. no its not a diesel but OK none the less.
Check the exhaust manifold bolts. they are a known failure. mine has 2 broken ones now that I will be fixing this winter.
At that mileage and with a lift check the front suspension. wheel bearings, ball joints, tie rod ends, etc.
Good luck!
Good luck!
