Wes_Tausend
Feb 28, 2014Explorer
johninedmonton wrote:
Hi Wes,
How do you like your v10 excursion? I've considered it instead of the diesel.
I have an expy el now. It's rated at 8,900 lbs. which is lower than a comparable f-150. I expect the new Eco boost wil be about the same. The issue I have with it is that 60mph with my 7,500 lb trailer destroys my fuel economy. Apart from that, it's a good rig.
Since the OP has once considered a V-10 on another thread, I guess we aren't hi-jacking this too bad.
I like my Excursion enough to have painfully stuck $8k into it for a new V-10. When the motor broke, the chassis was suddenly essentially worthless and I mentally wrote it off. So I was able to start over from nothing again and buy a 2000 Ex for $8k. I hope that makes sense, I had to replace it with something anyway, preferably with a known, reliable good engine this time around.
The V-10 is snappier than the 7.3L diesel (we have an F-250 7.3). The V-10 actually has more total power than the older 7.3L also. However, on the highway, the 7.3L runs right in it's max torque range, so hills don't easily cause it to slow and downshift to 3rd gear from OD, which the V-10 does often.
The result is the diesel gets slightly better fuel economy. The V-10 is much more quiet and pleasant to drive, especially in the winter. The old diesel sounds and smells like a tractor. The new ones sound better, as in less sound.
The Ex has gotten as low as 6.5 mpg, towing a 30' TT at 60-65 mph against the wind. On the way home the same wind existed and I was by myself so I drove 55 and got 9.9 mpg with the wind. I think it averages about 8, which I still consider, "destroyed fuel economy" compared to non-towing. Non-towing has netted as high as 14 highway and as low as 7 in the city, in winter (Note the diesel got 11/city while the Ex was in for repair.) Summer, the Ex will be around 9/city. Average highway will be near, or on, 13 mpg. We almost always drive my wifes thrifty small hybrid if possible. But the EX does allow the 8 passengers, if it works out that way, and also burns less fuel than two very ordinary 4-passenger autos.
All in all, the gas powered Ex won't improve on your Expy towing economy; a diesel Ex might, but it won't pay you back the upfront ownership cost unless you tow everyday. If you want a diesel for other less practical reasons, go for it. I did.
I have a Hensley hitch installed for towing right now, but I plan to take it off. I have also towed with an Eazlift WD (no anti-sway friction bars), the cheapest and oldest brand WD hitch alive, and it worked great, possibly partly because the Ex is so massive. The Hensley is a nuisance to hitch quickly and if I don't direly need it, I'm going to mothball it until I do, maybe a larger TT or smaller truck. I'm tired of being the last one of our group to leave the camp.
Wes
