rowekmr wrote:
Hello
I took it to mechanic/friend 180 miles away who replaced the front engine cover that had signs of cavitation and drained some oil out of the IC. He replaced the coolant with Ford Gold and performed an oil change.
So when you say he found "signs of cavitation" can I assume that he did not find a hole all the way through the front cover? If so, it's not fixed yet. I agree with others that say it "could" be an oil cooler problem or a head gasket problem. Either way, it's bad news.
If so, get it fixed or this is what's going to happen.
