Well I can now honestly I really appreciate Ford dealership service tactics. If it wasn't for their ridiculous inflation of shop hours and mark up of services I would not have done a search and found a shop I used before that is well versed in the powerstrokes.
He actually drove my truck with a smaller scanner to read actual road values and also used the IDS software back at the shop to see the snap shot of the values when the wrench illuminated. Turned out there was a 30F delta (highest) between the oil and coolant temps. To change my oil cooler he didn't raise the cab, checked my valve train and found 3 out of spec that he retorqued, bore scoped my EGR coolers (no significant blockage) and performed the flush before the oil cooler was installed to remove some of the gel that was in my coolant. He used a vacuum process to put in the new Ford Gold so as to eliminate/minimize air pockets. He also checked the computer software and performed a few updates including a dash update that will provide dash notification when in progress. He also said the newer software limits the regen cycles to higher (highway) speeds. He will let the coolant "cold soak" and double check the coolant level tomorrow before and after he drives to insure all is within spec.
I feel much better with his diagnosis and processes and believe the truck will have a good bill of health when I pick it up. All the weak points have been checked incl the front cover, oil/EGR coolers, valvetrain and coolant. It goes to show that while much of the older powerstrokes had issues because of bad design and improper maintenance some of the owner's woes came from dealerships that were not properly trained/staffed that either charged way to much or didn't fix the problem.
