- Johno02ExplorerThanks for the follow up. Will file for later.
- Joe417ExplorerHere's another,
http://www.t-molding.com/125in-white-t-molding.html - DaButcherExplorerI found on Ebay, looks right size, just not sure of color match.......If it's way cheaper than West & Barker I'll make it work.
Ebay molding clickyWagonqueen Truckster wrote:
Got mine on ebay - Wagonqueen_TrucExplorerGot mine on ebay
- DaButcherExplorerI think so, need to remeasure and give them a call
4aSong wrote:
DaButcher
Did you find what you needed at West & Barker?? - 4aSongExplorerDaButcher
Did you find what you needed at West & Barker?? - Wyo350ExplorerForgot to mention, if the new moulding fits loose put some silicon in the slot and tape down the t molding tell it has set up.
- Wyo350ExplorerTry woodworkers supply.
- DaButcherExplorerWest and Barker call it double lip T molding, thank you 4aSong, I had a couple hours of searching before making this post with no good results.
4aSong wrote:
If West and Barker does not have it then give up searching. Have purchased from them numerous times and they even will send a sample if requested, at least they did the last time I purchased from them. - Johno02ExplorerMight ask at a local cabinet shop. Lowes or Home Depot ar an option, but I have neverfound anything that would fit my needs there. Rockler woodworking is a thought. An RV place is another good bet. When you find some, please repost and let us know. I have a project coming up and will need some also.
