mich800
Mar 19, 2015Explorer
RCMAN46 wrote:
I did not see where you explain what the trailer is doing. Swaying, porpoising, rough ride????
Is the trailer level?
What are your weight numbers?
Yes, what is the issue? But I believe this is a mute point now as they replaced with the Hensley and are happy correct?
On a side note. Although you have adjusted to the Ford specs, have you tried one more and one less on the WD links. Mine will show a noticeable difference doing this with minimal changes in the measurements.
44,056 PostsLatest Activity: Jan 12, 2020
