cruz-in
Mar 22, 2015Explorer
RinconVTR wrote:
A number of RED LIGHTS have been ID'd!
1. The Hensley and Propride weight distribution is absolutely no different than all the other common systems (weight distribution is not what is patented within these designs) and all of the hitch's weight must be included as tongue weight. Even the stinger!
If you currently weigh around 1500lbs anywhere up front (jack/coupler...whatever) you're already over the Hensley TW spec without adding anything else.
2. Weighing the trailer at the jack vs the coupler...you are losing a good foot of moment (lever) arm acting on the coupler thus likely not getting the full & accurate TW. Take the tongue weight at the coupler!
I know eTrailer shows pics of the TW taken from the jack, but you are on the edge and need a very accurate weight to know where you're at.
Now all that said, may or may not be part of your ride issue. You wont know until you change the balance of your trailer.
What is clear, is that you NEED to change the balance, if for no other reason than to get in spec of the Hensley. You're asking for head failure or at least premature bushing wear if you continue as is.
Humm....I have extensively discussed this with Hensley prior to buying the hitch....as I expected my TW without the hensley to be someone where between 1200 and 1400 pounds... and was told very specifically the 1400/14000 rating applies to the trailer prior to hensley install...but I will double check with them tomorrow and report back here...
when you think about it, this makes sense, the average purchaser does not know the weight of the weight distribution hitch stuff they are purchasing to put on the trailer, they only know the TW of the trailer and are buying accourdingly...derating the capacity for the hitch components just does not make sense....a hitch of certain capacity is ment to be installed on a trailer of a specified TW and weight, not a trailer of a certain TW minius weight of hitch components.
For instance in my case, Hensley asked me what my TW was. I responded between 1200 and 1400 pounds. They answered, go with the 1400 boars to cover the higher end.
44,056 PostsLatest Activity: May 04, 2014
