mosseater wrote:
Ive flushed my trans several times and never had an issue with it.
The "transmission flush" services I have seen done is not a externally powered/pressurized flush that everyone seems to freak out about.
You just hook up the trans cooler lines to a setup that pulls fresh fluid in one line and collects the old fluid from the other.
Then you start the truck an let the trans pump circulate the fluid until it comes out clean.
WAY better then the old "drop the pan, drain the converter, and fill it back up" way of doing things.
