mekkerl wrote:
Wow -- great information from you all!
Seems this is the list I should give to the Dealership:
(totally NOT looking forward to the bill with this Duramax!)
Oil Change & Oil Filter
Fuel Filter Change
Transmission Fluid Flush & Filter
Brake Fluid Flush
Coolant System Flush
Power Steering Fluid Flush
Rear Differential Flush
Front Differential Flush
Transfer Case Flush
Rear Axle Lube
Inspect Brakes
Inspect Belts
Did I list everything correctly?!
The one thing you didn't list is a seriously lighter wallet.  I'm willing to bet if you give that list to the dealer, the minimum price on the bill will be $1,000.....probably closer to $1500.  All total, it's probably $250 in just fluids alone.
If you can turn a wrench you can do all of this yourself.
KJ
