Serp belt, yes, but only get an OE or a Continental belt. Idler and tensioner pullies, maybe, hoses maybe, all fluids up to date.
Most importantly, if you are still only running factory fuel filtration, the clock is ticking on your injector life and it's between 9 and 10 pm if they are going to fail at midnight.
Add 2 micron filter. Most important thing you can do.
Except the #4 injector line. If it's original still you're gambling on that. Replace it now or at least have a spare and the right size line wrench with you. And check all the injector hold down bolts as well.
The rest is subjective preventative maint, of which you've been pretty thorough already it appears.
The last thing I can think of is u-joints and carrier bearing. 50/50 shot at 100k and 15 years old, IMO. BUT, they don't fail suddenly. If one start's going, you can still drive for hours or days, depending.
