24rules wrote:
I agree but if the trailer is properly grounded there would be no stray voltage to be felt since the frame is part of the ground
I just did some work on a melted neutral bar in my trailer and discovered that there is no ground to frame on the 120 volt side, only on the 12 volt side. The ground from shore power goes to the grounding bar and all the outlets ground wires go to that bar. The bar is isolated and there is no ground wire to frame anywhere that I can find, is this unusual? I can clearly see where the 12 volt ground goes to frame.
