2112 wrote:
Let's dig into this a little deeper for future reference. Anyone feel free to correct me.
I recommend a 50ft 12AWG extension. This will ideally produce a 3V drop at 15A. The adapter will produce about a 1V drop. Considering 120V at the outlet, the camper should have 115V while drawing 15A. That's 1725W. I like to try to not exceed 1700W while on this extension chord.
Using conservative numbers to account for the converter:
Furnace = 100W
Fridge on AC = 350W
Water heater on AC = 1500W
Microwave = 1300W
Standard light bulb = 20W each
Using these numbers, you can operate your furnace, some lights and the fridge on AC without coming close to the 1700W allotment. You can operate the furnace, fridge and microwave for a short period of time. You can operate the water heater or the microwave, but not at the same time. It's called power management.
Forget about the air conditioner. I do not recommend operating it on an extension chord.
Generally good analysis...a couple of comments to add:
- Check the voltage at the RV. 120v is a nominal voltage. It's common and within spec for it to vary between 104-127v (and voltage will vary over the course of the day). If you are on the high end, that's fine but at the low end, you have less available power. We have a $10 voltage meter that we leave plugged into an outlet in the trailer that's easy to see from the couch (even better are automated systems that will cut the voltage if it gets too low).
- If you do want to run an electric space heater, look at the wattage. We've never seen 1700w unit (not saying they don't exist). Most we've had have been 1200w or 1500w. If you keep everything else on propane, you can likely get away with running one.
- Air/con (not likely needed in winter) is a different animal. Heaters just pull what they are rated for (in amps). Electric motors (like the one running the compressor) have two requirements. Start up and continuous operation. Start up is often a multiple times as many amps but once started, you are likely looking at 9-12amps continuous for the air/con. As long as it starts quickly without struggle, you can likely run the air/con. Voltage is more critical here. Resistance loads (like heating elements) pull a given amperage. If voltage is low, the only real problem is they put out less heat but otherwise don't really care about the voltage. Electric motors though generally pull a certain wattage. If the voltage goes down, it pulls more amps to keep the wattage up. Amperage is what burns up power cords.
