ScottG
Oct 13, 2017Nomad
As others have state, check voltage. Do so at both the oulets and at the pedestal outside.
I would also check the connections at the breakers in the panel. Manufacturers are notorious for not getting them tight.
FWIW, most of the items you mentioned (space heater & fridge) will use less current as voltage drops. So if your having issues with weak circuits, check connections first.
44,070 PostsLatest Activity: Jul 11, 2026
