westend
Oct 13, 2017Explorer
If the GFCI being tripped is rated for 15 amps (typical), the load of the window A/C or the heater may present a load higher than 15 amps. If there is anything else being powered by that same circuit, chances are you are over that theoretical 15 amps.
You can try using a different receptacle but older RV's are notorious for bad distribution, having just one or two circuits that power everything.
44,070 PostsLatest Activity: Jul 11, 2026
