jimh425 wrote:
mkirsch wrote:
To stay within the factory ratings on a 1500 pickup, there are NO options out there unless you camp naked, cold, and hungry.
Is this one of those wild generalizations? ;) Seriously though, lots of people have been camping with 1/2 tons for decades and staying warm although some may have been naked at times ... I can't say for sure. :D
Sure, you can't haul even a "normal" weight camper or a relatively heavy one like I have, but there are options. Four Wheel Campers makes a lot of lightweight models that can even go on tiny trucks, for example. http://www.fourwh.com/popup-truck-camper-customer-testimonials/
No, it is not a wild generalization.
Even the camper you show here starts out at around 800lbs if I am not mistaken. With NOTHING in it. No mattress, no seating, no appliances, no water tank, no amenities, period.
By the time you add in even meager options, supplies, gear, and passengers, you're at 1500+lbs, exceeding the payload capacity on nearly all 1500-series pickup trucks. Most also want to tow something.
I've weighed (pun intended) all the options. I've done all the math. I've gone down all the rabbit holes. It can't be done and stay within the factory ratings unless you use a "fake 1/2-ton" truck which is really a 3/4-ton truck with 1500-series badging to skirt license, tax, and/or HOA regulations.
All I am saying here is that it can't be done *within manufacturer's ratings* on a 1500 truck. If you decide to go forward, you have to do so with the assumption that you WILL be overloaded, and that doesn't always work out to your satisfaction, even if you are absolutely no danger to anyone else on the road.
