Groover wrote:
LowRyter wrote:
If you're within weight limits, it should work. Be prepared to get 5 mpg when towing. Keep it under 65.
My daughter gets about 11mpg towing her 3 horse gooseneck with living quarters behind her 2013 Ecoboost at 70mph. You can figure about 85% of what a diesel would give under the same situation.
A 3 horse trailer with living quarters could have a pin weight of under 2000 lbs or over 4000 lbs - not enough information here to think an F150 is OK towing a 5th wheel. I have a 3 horse no living quarters and the pin weight is OK for a 1/2 ton, but for stability, emergency braking, etc, the 3/4 ton is much better. I have looked at living quarters, but my 3/4 ton diesel is not enough truck... that is living quarters with water, waste, etc. Something you can actually use. Some living quarters are not much more than a bed and some cabinets.
