Before purchasing a portable air compressor you have to check out the
Milwaukee Inflator (WARNING ! This link is for the pump ONLY ! No battery, no charger ! I got mine with the small battery for only a few dollars more.)This thing look tiny but it is the "real deal" ! And it is portable !!
• Top off a car tire (28-35 psi) in under 1 minute. Fills a LT truck tire (30-45 psi) in under 4 minutes .
• TrueFill Auto Shut-off technology increases accuracy, protects from over-temp and over-fill.
• High efficiency pump and motor for true
120 PSI capability.
• Illuminated digital gauge with target and current pressure reading.
If you want to use it on Class A tires or airing up off road tires after lowering the pressure for sand, you had better have a high capacity battery and a spare !
For you grandparents that have to fill up inflatable tops, it does have adapters, but I made one for filling LARGE inflatables. But a 2" brass tire valve (under $2 on eBay). Take a hacksaw and cut of the end that would go through the rim. Remove burrs. Make volume ! I might not be fast, but you won't feel like you are blowing your brains out on that 3rd or 4th floaty !
Once you have one of these, then you can justify Milwaukee's nice 3/8" drill/driver. No Milwaukee margarita blender ... yet !
