sch911
Dec 15, 2014Explorer
SteveAE wrote:
Grandpa,
IF you want to run your microwave from your batteries and recharge them via solar, then you will likely need:
- Four batteries
- A 1200 Watt (or bigger) inverter
- Short and large (diameter) cables between the inverter and the batteries
- And a 200 to 300 watt (minimum) solar system (and plan to use power conservatively at that)
This type of system works well ..... for me. But you best verify that this is really what you want before jumping in as it isn't cheap to do.
Steve
This is the best answer so far IMHO. You'll definitely need to go with an inverter with about 150% of the MW's steady state draw to pull this off. Perhaps a better option for you would be a small generator to recharge your batteries each morning.
44,071 PostsLatest Activity: Aug 30, 2026
