DWeikert
Oct 21, 2013Explorer II
I can't speak for that specific model, but the Dometic CR-1110 in my Northstar has run at temps down to 19*F/-7*C. Northstar uses the same exterior venting for either compressor or absorption refrigerators so the cooling unit should've thought the temperature was well below 16*C.
sabconsulting: I'm not sure the wiring is that critical. #14 wire should be sufficient even if the batteries are on the opposite side of the camper from the fridge. Average current draw on my model is under 4 amps. I can't imagine the startup surge being enough to need more than 14 gauge.
