popeyemth
Oct 23, 2013Explorer
pezvela wrote:popeyemth wrote:
700 watt continuous Harbor Freight inverter
12 hours with furnace running some using one group 27 Battery
Setup in pic is just a temp
All of 12 hours? What do you do, camp for one day at a time?
I cant see how that's gonna work without solar or driving every day or so. Especially not with all the other demands from the camper.
100 watts of solar would let this run practically indefinitely as the compressor dosent run continuous and the furnace could be off or turned way down in the day.
This setup uses nearly the identical wattage as a 12 volt compressor . Did you miss the part about the furnace running?
Look at a map sometime.
