bigfootford wrote:
Trailer, Class A, C's do not reply to this post please.
Most of us "CAMPER" folks do not have much more room for over 200watts of solar.
Some of you guys that own one of these fridges should use a trimetric or equivalent and tell us your Amp hour usage for 24 hrs. in cold and hot weather.
The way I see it, if the amp draw is 5 amps when running and the fridge only runs 1/4 of the time that would be 1.25 AH..
1.25 AH X 24hrs =30 AH....
Our rig is setup as lean as it can be for AH use. We rarely hook up to shore power except when home.
We use about 20AH Summer and 25AH Winter per day.
So If I have one of these Compressor fridges using the above "MINIMUM RUN" numbers I would be pulling 50AH to 55AH per day.
I have 200watts of solar... During the summer and winter there would be no way that I could keep up...
I would need to run the Gen to complement the charging...
Most of us solar guys have solar to keep us from using our gen's and we prefer quiet.
Lastly, over the past 40+ years my beer, milk, steaks have stayed sufficiently cold using Absorption Fridges as have 10 of thousands of folks so I don't quite get the need for a AMPAHOLIC compressor fridge.
Jim
Compressor technology has been around for a long time and judging by the fact that it is used by 100% of domestic/commercial fridge/ freezer applications, until replaced by other better, more efficient appliances, is still the way to go.
Absorbtion technology was developed in RV,s etc because most of the time, owners were not hooked up to the grid. Back 40 years ago, batteries were less efficient, nobody had a generator, vehicle alternators had relatively low output and solar was non existent or way too expensive and as you already had propane as a fuel for cooking/heating, absorbtion fridges worked a lot better than the ice box.
Nowadays, if you have enough solar, batteries and a high out put alternator, a compressor fridge is an alternative to the propane fired fridge.
We started with 190W of solar and found when the desert temps got over 90F in the day we were sometimes running a bit short so we added another 140W and couldn't be happier. Our panels take up about half of one side of our roof with the canoe taking the other side. We have a 9.5' TC.
I don't know how many times we have pulled into a place which is way out of level for the night or have sat for hours on a 14% ramp waiting for a ferry with no worries about ill effects on the fridge.
Compressor fridge advantages:
Faster cooling and freezing
Less energy use
Can set up on any angle up to 30 degrees.
Almost no fire hazard
Can run in tunnels, ferries etc.
Do not have to shut off when fueling
More consistant cooling/freezing
180 nights, 5 with shore power, 3-4 hours genny time.
We need and choose a compressor fridge because of the camping lifestyle we have. Others may choose differently.
Dave
