RoadloverExplorerJan 22, 201412 volt electric blanketI'm trying to locate a queen size 12 volt electric blanket but not having much luck. People talk about them but the closest I find are electric car blankets that are only 42x58. Thanks
RoyBExplorer IIIJan 22, 2014Just get two of them - problem solved... Better yet just get two twin size 12VDC electric blankets... You also need to know how many DC AMPS does the 12VDC TWIN SIZE electric blanket draws from your 12VDC battery...You will need some pretty substantial batteries if these draw 15-20AMPS each in addition to a very good 12VDC socket setup..I am not a good fan of 12VDC appliances due to the high DC currents involved.Roy Ken
Related Content12 volt blanket?electric blankets ??12 volt only refrigeratorElectric Blanket ?12 volt heated blanket
