plasticmaster's avatar
Oct 30, 2017
12 volt ideas for exterior of camper???
Now that I've removed my electric stabilizer jacks from my camper, I need to cover the hole where the switch for the jacks were located. I thought about just covering it with some sort of trim plate, but then thought it would be a shame not to utilize the existing 12 volt power that's already run to this location. I thought about a 12 volt led light or possibly a cigarette power plug. Does anyone have other ideas? I want it to be functional and also completely cover the hole from where I removed the jack switch. If you have a link to go along with the idea, that would be great. Thanks.
  • Doncom wrote:
    Anderson Power Pole
    If you’re not familiar with Anderson Power Pole, take a look at this. I have connectors on wire pigtails with USB, LED lights and all sorts of 12 volt stuff.
    I've read several negative comments on the Anderson connector, that they don't stay mated very well without help, such as tape or a zip-tie placed lengthwise.
    Have you found this to be an issue?
  • Anderson Power Pole
