AnEv942
May 20, 2014Nomad
I assume the controller display alternates between voltage and current, voltage showing status of battery, current being the amps sent to battery. What is max 'current' you've seen displayed? (with battery hooked up).
Meter-check against the panel meter..when camper plugged into truck-solar meter showing 13.1 or what ever, your multi meter should read close to the same at truck battery.
At 14+, the batteries on charger? My assumption. So camper battery took charge? Has it stabilized, holding charge since last night?
44,066 PostsLatest Activity: Mar 14, 2015
