nycsteve
Jun 15, 2014Explorer
zman-az wrote:
110vac has nothing to do with it. Is a all about the pump and the motor to run it.
If you really want a portable air compressor you want this. Oasis
And if you are cheap and creative you can pull that pump out of a 80's AMC Eagle and hook it up with a belt to your current automotive engine to power it. I did all this for under $100 to a jeep I had. You really can run a impact gun off of it without a air tank.
If you have this compressor, how long to get a truck tire from 20#s to 80#s?
Also saw on the link auto tire deflators, the Oasis Trailheads. I have these. They atre adjustable and fast. Unscrew the valve caps, screw these on. You get 4 and I airdown completely in less than 5 minutes, accurately with no checking of pressure needed.Great timesaver.
44,068 PostsLatest Activity: Jun 01, 2026
