navyblue's avatar
navyblue
12v electric.
I just bought a very old TC. It was built locally and the guy is no longer in business. My question I where can I find a wiring diagram that I can use re-wire my camper. It has a 6 wire connector from the wiring harness to the camper. But it seems the original builder used his own diagram... I am finding lots of broken wires and have no idea what is going on inside the camper. I am hosting for the next month and hopefully will have time to work on a new wiring situation which is more conventional. Inside wiring setup so I can have a better inside wiring and run a new set of lights on the rear of the unit.
  • If I was wiring it from scratch, I'd go with the 7 RV blade connector. It's larger allowing you more room to work on things, I think they're better made, and the extra wire allows you more flexiblilty. It may also handle hire amperage if you need it.
    ETrailer.com has a lot of good information on it.
    ETrailer connector Clicky
    Bill
  • I see what you are saying. Right now I have a 6ford round. Should I go to a 7conclusion wire plug?
  • If you couldn't get the wiring diagram from the guy that built the camper, and you can't provide a brand and model to us, you're sunk.
    Really it's not that complicated. Treat the lights like one wiring system, and the 12V interior electrical like a completely separate system. The only place they will connect together is at the 7-pin RV plug that connects to the truck. Even then, the only COMMON connection will be the ground (battery -).
    For the internal wiring, think in terms of a wiring "bus." All the +'s get connected together (12V+ from truck's trailer plug, converter 12V+ output, house battery +, lighting, appliances). All the -'s get connected together (ground from truck's trailer plug, converter ground, house battery -, lighting, appliances).
    You'll want to separate the + connections for various appliances and lights onto separate circuits with a fuse panel. AutoZone has a nice 6-circuit fuse panel that uses automotive type fuses.
    All the - connections can be made together on a bus bar.
  • You'd be hard pressed to find a schematic for even a new unit let alone an old one. They just run wires as needed and don't follow any true schematic.
  • sounds like your best bet is to just clip the wires and start over putting inside like a northwoods unit.. makes it alot easier later on
  • Since it sounds like you'll have to start from scratch, can you use a standard 7-wire wiring diagram for a trailer with the expection of using a heavier wire for the lighting?
    Bill
