"All other 12V things work fine" implies that the radio is still working.
It won't hurt to check the fuse panel for blown fuses, but generally the light by the back door is not on its own fuse, so the likely culprit is a broken wire. The solution is to run a new wire.
One thing you absolutely do NOT want to do is just "grab power from anywhere." Certain things are on certain circuits to keep from overloading the wire used. You need to trace the wire back to where it started and connect there.
Unfortunately that is easier said than done in a camper, because the wires are generally concealed and you would have to tear the camper apart to access them. If you can get the wiring diagram, that will tell you where the wires start and end.
A hack way to deal with running new wires without gutting the camper is to just run wires using the "shortest distance from point A to point B is a straight line" method. But there are also ways to conceal the wires without having to gut the camper too if you're creative and careful.
