BiggyJ's avatar
BiggyJ
12v lighting issue... Could use some help :) (32BHDS)
Not sure where to put this. Move it if it is not where it should be.
Thank you.
2007 Keystone Hornet 32BHDS
Power Converter PM3-55-MBA
OK... so I hate trying to figure out electrical issues in my 8 mo. (07) “new to me” travel trailer.
This seems odd to me but may be a common lighting issue to someone here.
Battery: 13.7v
Control panel: All connectors with wires attached: 13.2v on fuse output side.
Lights in bedrooms, bathroom and the slide-out will come on bright and as normal.
The outside door light, the above kitchen sink light and the three lights that are in the center of the trailer and operate off their own switch, I'm having problems with.
The outside door light and the three lights that are in the center of the trailer run by one switch plate. One switch for outside light and one switch for the three lights that are in the center of the trailer.
The above kitchen sink light has it's own push button switch mounted on it.
The three lights that are in the center of the trailer have their own switch as well but we just always leave the switches on and use the switch panel that controls them all.
What they are doing: Started awhile back, flickering a bit, getting dim, (about 40% brightness) and every now and then, just go off. All of them.
Now: sometimes, after turning on, they will come on slowly like the voltage is building up, while flickering.
Sometimes they will not come on right away at all. I can leave the switch on and sometimes they will come on within a few seconds and sometimes they will come on 5-10-15 minutes later. And then they may just come on instantly at full brightness.
Wiring and switches: switches seem functional when testing for continuity but why the hell I can put my DVM test leads across the two terminals and get 12 volts is new to me. I'm just used to the good old -12vdc and +12vdc
In other words, one switch terminal has -12 on it and the other +12. And that’s the way it’s always been I guess. Seems like when the switch is closed, that would be a direct short! Guess not ?
All internal lights are 12v.
Things I am curious about:
Do all lights go through the power center or are the ones that always work hooked up directly to the battery?
Or should ALL wiring come in to the control panel from behind the CP mounting plastic box?
Anyway, I sure would appreciate some help from someone. Pain for my wife to do the dishes with a flashlight.
Also, please note that the Power Converter PM3-55MBA hardly ever comes on now. Matter of fact, I think I remember hearing it come on only twice in the past few days.
Thank you,
John
PS – Other than your direct response help here, It would be very nice to have a wiring diagram for this TT. And possibly the correct way to test inverter/converter.
  • Unless a previous owner messed with it, all of the lights should go through a fuse in the 12V panel.
    Have you determined if the malfunctioning lights are on their own circuit?
    Try measuring voltage when the switch is closed but the lights are not working. Is there power available at the light when it's not lit up?
    Have you tried tightening all the connections? And checking all grounds?
