nkc914's avatar
nkc914
Lighting issue
I have e lights that have stopped working. Just days ago all worked well now one in my main hallway and the two sconces in my slide out have stopped working.
I used a multimeter and there is no continuity or voltage showing ?
nothing has changed to cause this that I know of, other lights in the same hallway are working fine. I checked the breakers and fuses and could not see any picked wires in the slide out.
This is a 1999 Coachmen Catalina.
Thank you for any help you can provide.
  • Drew thanks for the thoughts. I removed the light fixture thinking it is defective. As far as I know there are no wall switches for any of these lights. And as far as I can tell therr is no power to these.
    Thank You
    Mike
  • A couple of thoughts based on my Coachmen motorhome of a similar vintage:
    1. In my unit, there are a number of lights that are controlled by both a switch on the wall and a switch on the light itself. If one or the other switch is off, the light does not turn on. My solution was to disable the switch on the light.
    2. If the lights are plastic ones with a slide switch on the light itself like mine, the plastic switch connects to the actual electrical switch in the light with an internal plastic connector piece. I had one of these get mutilated to the point where it wouldn't engage the internal switch properly. They could also conceivably get out of position and not work. At any rate, the outer plastic switch piece is held in with a couple of springy tab things on its sides and can be rather easily removed to fiddle with the mechanism (or the whole light unit can be removed from the ceiling by unscrewing a couple of screws under the diffuser) and the switching gear inspected and adjusted as needed.
    To solve both problems at the same time, I removed the inner intermediate plastic pieces for the lights that were switched by wall switches, disabling the switches on the fixture (making sure they were set to the "on" setting of course!) and used some of them to replace the mangled ones in one or two other fixtures.
