Boon Docker wrote:
Doesn't matter either way 6v or 12v.
If one 12v fails the other one will not function properly after it has been discharged by the faulty one. :W
SoundGuy wrote:
Only possible if those two 12 volts are run simultaneously in parallel ... run them sequentially and one has nothing to do with the other. With 6 volts one has no choice but to run both together at the same time. Touche. :W
Huntindog wrote:
But you gotta tie them together for your inverter use: Touche X2
No I don't, nor does anyone else. I only use a single G27 and load support with my truck when under heavy load from my 1000 watt PSW inverter. When the inverter is under relatively light load I still use it but don't even bother with load support - works like a charm. :B With dual 12 volts, run one as a primary, the other as secondary, wired through a
Blue Sea m-Series 6007 Dual Battery Switch.
FWIW, I also run my propane tanks sequentially - don't care whether anyone else approves or not. Touche 3. :W
To the OP - I personally would prefer dual 12 volt G31s if for no other reason I can always run on one 12 volt but never one 6 volt, but that said if dual 6 volt GC-2s fit better where I wanted to put them then I'd go with them instead. Don't let forum pundits with their so-called "expertise" sway you one way or the other with their armchair biases - either will work just fine for your application, albeit with some differences that are worth understanding but not worth losing sleep over. ;)
