Boon Docker wrote:
marcsbigfoot20b27 wrote:
Just did 9 day boondock and even one morning after lots of clouds the previous day (solar) I was down to 12.3v and when my GF fired up the coffee maker 115 amps and then the microwave 130 amps, the 2000 PSW inverter didnt make a sound. This was with 3 AGM grp 31 duracell in parallel.
With my previous setup and 2 GC2 the inverter would alarm.
That must be quite the 2000 watt PSW inverter you have that can run a microwave and coffee pot at the same time with batteries at 65% SOC.
Where can I get one of those awesome inverters?
I guess I could go edit my post and say....
was down to 12.3v and when my GF fired up the coffee maker 115 amps, added lots of cold creamer and then used the microwave @ 130 amps to heat the coffee back up.....
I just thought most would figure out that they were not on at the same time, my bad.
