nwbearcat1998's avatar
May 31, 2015
12v water pump intermittent
Hello, I own a good 004/keystone cougar and throughout the day, the water pump runs for almost a second with none of the faucets turned on.
I cannot find any leaks around the faucets that are visible. The only one I can't check is the shower.
Does anyone have any trouble shooting suggestions?? Do I need a new water oump?
  • donn0128 wrote:
    Mom of the faucets turned on??? I have no clue what your asking. Can you rephrase your question?
    "NONE"
  • bid_time wrote:
    If there is no leak than in has to be Air in the lines. Get rid Of all the air and the pump will stop.
    That or the non-return valve in the pump is leaking down.
  • If there is no leak than in has to be Air in the lines. Get rid Of all the air and the pump will stop.
  • Mom of the faucets turned on??? I have no clue what your asking. Can you rephrase your question?
